Recommendations around outdoor temperature/humidity sensors in 2025?
What are the current recommendations around temperature/humidity sensors for outdoor use, that are compatible with HomeAssistat?
I know that traditionally, the consensus was that 433Mhz/915Mhz sensors were better, due to better range, better battery life, and lower cost. However, is that still always the case, for all of those attributes?
Some of the BLE/wifi options seem alright - you do get less range (50m or so) - but if you have either BLE proxies, or good outdoor wifi coverage, it seems they’re a viable option?
I put together a quick table with the options I’m aware of:
Model HA Support? RF Frequency Battery (Battery Life) Price (AUD)
Govee H5179 Yes (BLE only) 2.4Ghz (BLE/Wifi) 3 x AA batteries AUD 27.50
Shelly BLU H&T Yes 2.4Ghz (BLE) 1 x CR2032 (3 years) AUD 39.00
Accurite 06002M Replacement Sensor Yes (via rtl_433) 433Mhz 2 x AA batteries AUD 34.00
Ecowitt WN32 Outdoor Sensor Yes (via rtl_433) 433 Mhz 2 x AA batteries (1 year) AUD 25.99
What do people think - are the Accurite and Ecowitt sensors still better options?
They don’t really seem cheaper than the BLE/Wifi options nowadays - and the battery life isn’t that much better, at least compared to say the Shelly Blu H&T?
Or what else do people recommend?
Good old xiaomi LYWSD03MMC - the ones you could buy a pack of 4 for ~$10 with batteries in the past and that can be flashed with aftermarket firmware. Can be captured by any esphome device (bluetooth proxy) with bluetooth :signal_strength:
We got some glued outside (naturally protected from direct rain from the top) and they are going strong, year after year :chart_with_upwards_trend:
