Recommendations for cheap zwave temp sensor?
I have a Aqara zigbee temp sensor in garage. I would like to put another zwave one in there in case zigbee goes down. My experience is Zigbee is less reliable than Zwave.
So I’d like to add a zwave temp sensor in there as well for backup. But man, they are hard to find or come has part of a motion sensor and costs $50+. Any recommendations for a cheaper one?
I have Fibaro door/window sensor on my carage, i added DS18B20 temperature sensor in to it :slight_smile:
EDIT: i propably pasted newer version link, since it says it has temp sensor built-in :slight_smile: Which is not good imo, since temp sensor would be pretty near door, and might not give a temp you want to measure. My sensor has 2m wire so i can set it away from the door.
This is the one i have : https://www.fibaro.com/files/instrukcje/eng/DoorWindowSensor%20FGK-101-107%20ENG_v21-v23.pdf
