Recommendations for heavy duty Zwave appliance plug
I’d like monitor the power coming from my dryer to know when it’s done. I’m in the United States and need a plug that supports 220VAC and Z-wave Plus. Any recommendations? Most of the devices that I’ve been able to find are only 120VAC.
There are no “plugs” that support 220/240V. There are two options.
  1. GE Heavy duty relay
    https://www.amazon.com/GE-Enbrighten-120-277V-Monitoring-SmartThings/dp/B07QX8TMLJ/ref=sr_1_3?dchild=1&keywords=ge+heavy+duty+z-wave&qid=1586802411&sr=8-3
  2. Aeotec heavy duty relay
    https://www.amazon.com/Aeotec-Security-controller-electricity-consumption/dp/B00MBIRF5W/ref=sr_1_2?dchild=1&keywords=aeotec+heavy+duty&qid=1586802437&sr=8-2
Neo Coomcam are fulfilling your requirements, but If I’m not wrong - in USA plugs are 120V?
https://szneo.com/en/products/show.php?id=189
Most are 120V in the US, but some dryers are 220/240 V.
Thank you!
Might want to browse the z-wavealliance.org site. You’ll probably find more options over there and even with the options you have already, you’ll be able to see details about configuration parameters and the like.
Here’s the direct link:
https://products.z-wavealliance.org/
I got the GE one @simplextech linked to for my water heater and it’s been working well. It replaced one of those “Little Gray Box” timer boxes and directly wires into the wall and the water heater. If your dryer has a plug, it’ll be a bit more work.
Good info. You should let @blich know as he was asking for it :slight_smile:
