Recommendations for WIFI to 306Mhz bridge for Garage Door
Hi all, I have a garage door that I need a quick solution for.
It uses an old DEA 306Mhz remote not the standard 433mhz. I was looking for some hardware recommendations that integrate into Home assistant that would let me learn the static 306mhz command so I can control the door from Home Assistant.
I will when the weather improves hard wire a relay to control it but the location is in the French alps with consistent minus c weather so that project can wait until after Easter!
Thanks in advance!
Cheers
Stuart
Try to find cc1101 with 315mhz antenna, you can tune it down to 300. Not easy to find though.
