Recorder question / help
Can someone please look at my recorder setup and let me know if it looks correct? I am trying to exclude the entities from being recorded that are using lots of bytes. I entered the byte hungry entities into the exclude area but they are still showing up when I check SQLite. Also can someone dumb down the definition of entity glob for me lol. Thank you
Excluding entities doesn’t remove old data.
I have manually deleted my database file, restarted HA and ran SQLite again to see my byte usage per entity and the entities that I have “Excluded” are still showing new usage. I’m not sure why they aren’t excluded
I never had any luck using both includes and excludes. Use either includes or excludes not both. The logic for both as described here does not seem to work.
