I have HAOS running in a VM on my Truenas server. I’ve been running it for several months, and finally noticed the recorder does not start.
In parrallel, I spun up another copy of HAOS in a VM on a fresh install and noticed that it also has a recorder that fails to start.
Copy of the log below.
Can anyone suggest how I might fix this issue?
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/base.py", line 146, in __init__
self._dbapi_connection = engine.raw_connection()
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/base.py", line 3298, in raw_connection
return self.pool.connect()
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/pool/base.py", line 449, in connect
return _ConnectionFairy._checkout(self)
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/pool/base.py", line 1263, in _checkout
fairy = _ConnectionRecord.checkout(pool)
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/pool/base.py", line 712, in checkout
rec = pool._do_get()
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/pool/impl.py", line 179, in _do_get
with util.safe_reraise():
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/util/langhelpers.py", line 146, in __exit__
raise exc_value.with_traceback(exc_tb)
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/pool/impl.py", line 177, in _do_get
return self._create_connection()
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/pool/base.py", line 390, in _create_connection
return _ConnectionRecord(self)
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/pool/base.py", line 674, in __init__
self.__connect()
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/pool/base.py", line 900, in __connect
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/pool/base.py", line 896, in __connect
self.dbapi_connection = connection = pool._invoke_creator(self)
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/create.py", line 646, in connect
return dialect.connect(*cargs, **cparams)
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/default.py", line 622, in connect
return self.loaded_dbapi.connect(*cargs, **cparams)
File "/usr/local/lib/python3.13/site-packages/psycopg2/__init__.py", line 122, in connect
conn = _connect(dsn, connection_factory=connection_factory, **kwasync)
psycopg2.OperationalError: could not translate host name "home-assistant-postgres" to address: Name has no usable address
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 912, in _setup_recorder
self._setup_connection()
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1427, in _setup_connection
migration.pre_migrate_schema(self.engine)
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 323, in pre_migrate_schema
inspector = sqlalchemy.inspect(engine)
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/inspection.py", line 140, in inspect
ret = reg(subject)
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/reflection.py", line 313, in _engine_insp
return Inspector._construct(Inspector._init_engine, bind)
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/reflection.py", line 246, in _construct
init(self, bind)
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/reflection.py", line 257, in _init_engine
engine.connect().close()
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/base.py", line 3274, in connect
return self._connection_cls(self)
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/base.py", line 148, in __init__
Connection._handle_dbapi_exception_noconnection(
err, dialect, engine
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/base.py", line 2439, in _handle_dbapi_exception_noconnection
raise sqlalchemy_exception.with_traceback(exc_info[2]) from e
self.__connect()
sqlalchemy.exc.OperationalError: (psycopg2.OperationalError) could not translate host name "home-assistant-postgres" to address: Name has no usable address
(Background on this error at: https://sqlalche.me/e/20/e3q8)
