Redirect TTS output of Satellite1
I just assembled a Satellite1 from futureproofhomes.com. I’m trying to redirect the response to a media player on my whole house speaker system. I’ve hit a wall. I thought it would be a no brainer, but I can’t figure it out. Has anyone been successful doing this?
thanks
I’m not familiar with the Satellite1, but I suspect you’ve hit the same wall as the rest of us.
It seems to be a feature of Assist that responses to built in sentences can only be played through the speaker on the device that heard the command.
If you use custom sentences and intent scripts you can send the response anywhere you like, but otherwise Assist is a black box.
It would be more accurate to say that the voice_assistant component for ESPHome is designed to play the answer file by itself. But the developers leave the option to use a link to the generated file for your own needs.
If the developers had left the voice pipeline events inside HA, it would have been more convenient and there would have been no need to make changes to the satellite configuration. But this decision was abandoned.
Damn right. :roll_eyes:
How do you access this?
You can get the url value and pass it to the HA or play it on a mediaplayer. This is used in many third-party projects
on_tts_end (Optional, Automation): An automation to perform when the voice assistant has finished text-to-speech.A URL containing the audio response is available to automations as the variable x.
I’ll give that a try. Thanks…
Do you have a link to documentation? Or an example?
This is text from the esphome documentation, see the voice_assistant article.
If you google it, you’ll get some examples. Also look at the ReSpeacker-Lite config file, in this project values are passed as events.
Ah, thanks. So this is unique to ESPHome devices.
Or you can use a ESP32-S3 Box and put some custom firmware on it which has an “External Speaker” option so you can route all audio and responses to any Media Player (even Amazon devices).
LINK:
You can also do something similar with the M5Atom stack little unit.
How to send TTS reply from Voice Assistant to a separate speaker and be able to change it in the UI - ESPHome - Home Assistant Community
maybe this will help
