Reduce multiple curl into single for multiple sensors
I think the host is not liking multiple curl calls and it got me thinking that each curl gets all the data needed, so why do I need repeated calls?
I have this in my configuration.yaml:
command_line:
  - sensor:
      command: "curl -k -u <USER>:<PASSWORD> https://ws.otodatanetwork.com/neevoapp/v1/DataService.svc/GetAllDisplayPropaneDevices --header Content-Type:application/json"
      name: "Propane Tank Neevo 371 Gallons"
      unique_id: propane_tank_371_gallons
      value_template: "{{ value_json[0].Level|float(0) * 2.4 if value_json[0].Level is defined else this.state }}"
      scan_interval: 157680000
      state_class: measurement
      unit_of_measurement: "Gallons"
  # 371 Propane
  - sensor:
      name: "Propane Tank Neevo 629 Gallons"
      unique_id: propane_tank_629_gallons
      value_template: "{{ value_json[1].Level|float(0) * 1.2 if value_json[1].Level is defined else this.state }}"
  # 629 Propane
  - sensor:
      name: "Propane Tank Neevo 255 Gallons"
      unique_id: propane_tank_255_gallons
      value_template: "{{ value_json[3].Level|float(0) * 1.2 if value_json[2].Level is defined else this.state }}"
  # 255 Propane
  - sensor:
      name: "Propane Tank Neevo 76 Gallons"
      unique_id: propane_tank_76_gallons
      value_template: "{{ value_json[4].Level|float(0) * 1.2 if value_json[3].Level is defined else this.state }}"
  #76 Propane
  - sensor:
      name: "Propane Tank Neevo 125 Gallons"
      unique_id: propane_tank_125_gallons
      value_template: "{{ value_json[5].Level|float(0) * 1.2 if value_json[4].Level is defined else this.state }}"
  # 125 Propane
  - sensor:
      name: "Propane Tank Neevo 630 Gallons"
      unique_id: propane_tank_630_gallons
      value_template: "{{ value_json[2].Level|float(0) * 2.4 if value_json[5].Level is defined else this.state }}"
  # 630 Propane
  - sensor:
      name: "Propane Tank Neevo 6 Gallons"
      unique_id: propane_tank_6_gallons
      value_template: "{{ value_json[6].Level|float(0) * 2.4 if value_json[6].Level is defined else this.state }}"
# ??? Propane
Each curl call yields this response:
> [{"CompanyFillRequestAvailable":false,"CompanyId":"29014dc1-acd3-4abe-9e03-0054f48393da","CompanyImageId":null,"CompanyName":"yyyy Energy Inc.","CompanySupportPhoneNumber":null,"CustomName":"371","DealerId":"0148e47d-980b-4f4a-bd5c-c835e48c8a02","Id":"c99fd97d-2d7e-437f-a55b-9b4bd46f2701","IsOwner":true,"Latitude":yyyy1872,"Level":9,"Longitude":-xxxxx289,"NotifyAt1":40.00,"NotifyAt2":25.00,"NotifyCriticalLevels":true,"NotifyDispatch":false,"NotifyDispatchEnabled":false,"NotifyFillDetection":true,"Product":"Propane","SensorMaxLevel":null,"SensorMinLevel":null,"SerialNumber":20196761,"TankCapacity":908.49,"TankFormType":1,"TankLastPressure":null,"TankPressureDisplayUnitSymbol":"kPa","TankPrimaryValueType":0,"ThemeInfo":null},{"CompanyFillRequestAvailable":false,"CompanyId":"29014dc1-acd3-4abe-9e03-0054f48393da","CompanyImageId":null,"CompanyName":"yyyy Energy Inc.","CompanySupportPhoneNumber":null,"CustomName":"629","DealerId":"0148e47d-980b-4f4a-bd5c-c835e48c8a02","Id":"236d578d-f835-4e41-8a09-d20a93df50b3","IsOwner":true,"Latitude":yyyy5841,"Level":75,"Longitude":-xxxxx338,"NotifyAt1":30.00,"NotifyAt2":20.00,"NotifyCriticalLevels":true,"NotifyDispatch":false,"NotifyDispatchEnabled":false,"NotifyFillDetection":true,"Product":"Propane","SensorMaxLevel":null,"SensorMinLevel":null,"SerialNumber":20527575,"TankCapacity":454.24,"TankFormType":1,"TankLastPressure":null,"TankPressureDisplayUnitSymbol":"kPa","TankPrimaryValueType":0,"ThemeInfo":null},{"CompanyFillRequestAvailable":false,"CompanyId":"29014dc1-acd3-4abe-9e03-0054f48393da","CompanyImageId":null,"CompanyName":"yyyy Energy Inc.","CompanySupportPhoneNumber":null,"CustomName":"630  Correct","DealerId":"0148e47d-980b-4f4a-bd5c-c835e48c8a02","Id":"a86e10ad-cb5e-449d-a606-ffdae0e1c769","IsOwner":true,"Latitude":yyyy5976,"Level":72,"Longitude":-yyyy9904,"NotifyAt1":30.00,"NotifyAt2":20.00,"NotifyCriticalLevels":true,"NotifyDispatch":true,"NotifyDispatchEnabled":false,"NotifyFillDetection":true,"Product":"Propane","SensorMaxLevel":null,"SensorMinLevel":null,"SerialNumber":24045716,"TankCapacity":908.49,"TankFormType":1,"TankLastPressure":null,"TankPressureDisplayUnitSymbol":"kPa","TankPrimaryValueType":0,"ThemeInfo":null},{"CompanyFillRequestAvailable":false,"CompanyId":"29014dc1-acd3-4abe-9e03-0054f48393da","CompanyImageId":null,"CompanyName":"yyyy Energy Inc.","CompanySupportPhoneNumber":null,"CustomName":"255","DealerId":"0148e47d-980b-4f4a-bd5c-c835e48c8a02","Id":"b9310be9-b276-4294-b09a-11ac67b20cfd","IsOwner":true,"Latitude":yyyy3741,"Level":64,"Longitude":-yyyy3814,"NotifyAt1":30.00,"NotifyAt2":20.00,"NotifyCriticalLevels":true,"NotifyDispatch":false,"NotifyDispatchEnabled":false,"NotifyFillDetection":true,"Product":"Propane","SensorMaxLevel":null,"SensorMinLevel":null,"SerialNumber":24122799,"TankCapacity":454.24,"TankFormType":1,"TankLastPressure":null,"TankPressureDisplayUnitSymbol":"kPa","TankPrimaryValueType":0,"ThemeInfo":null},{"CompanyFillRequestAvailable":false,"CompanyId":"29014dc1-acd3-4abe-9e03-0054f48393da","CompanyImageId":null,"CompanyName":"yyyy Energy Inc.","CompanySupportPhoneNumber":null,"CustomName":"76","DealerId":"0148e47d-980b-4f4a-bd5c-c835e48c8a02","Id":"8f3c2705-39cc-461e-aff5-9251c2eefb5a","IsOwner":true,"Latitude":yyyy0257,"Level":72,"Longitude":-yyyy9472,"NotifyAt1":30.00,"NotifyAt2":20.00,"NotifyCriticalLevels":true,"NotifyDispatch":true,"NotifyDispatchEnabled":false,"NotifyFillDetection":true,"Product":"Propane","SensorMaxLevel":null,"SensorMinLevel":null,"SerialNumber":24470704,"TankCapacity":454.24,"TankFormType":1,"TankLastPressure":null,"TankPressureDisplayUnitSymbol":"kPa","TankPrimaryValueType":0,"ThemeInfo":null},{"CompanyFillRequestAvailable":false,"CompanyId":"29014dc1-acd3-4abe-9e03-0054f48393da","CompanyImageId":null,"CompanyName":"yyyy Energy Inc.","CompanySupportPhoneNumber":null,"CustomName":"125 ","DealerId":"0148e47d-980b-4f4a-bd5c-c835e48c8a02","Id":"3c3dcd64-85cc-4961-8489-d210861382ee","IsOwner":true,"Latitude":yyyy0339,"Level":75,"Longitude":-yyyy8042,"NotifyAt1":30.00,"NotifyAt2":20.00,"NotifyCriticalLevels":true,"NotifyDispatch":true,"NotifyDispatchEnabled":false,"NotifyFillDetection":true,"Product":"Propane","SensorMaxLevel":null,"SensorMinLevel":null,"SerialNumber":24554970,"TankCapacity":454.24,"TankFormType":1,"TankLastPressure":null,"TankPressureDisplayUnitSymbol":"kPa","TankPrimaryValueType":0,"ThemeInfo":null}]
What is the easiest/best way to extract all 7 “LEVEL” values and assign each to separate sensor using only a single curl call?
Thank you.
You could use curl to save the content as a file and then use e.g. REST integration/sensors to read from the file.
EDIT
Amother option is to put the whole output in one sensor-attributes and then use template entities (if stil lneeded), this may or may not need JQ to fiddle the data as you like it…
this would then look like
    command: >
         echo "{\"whateverattribute\":" $(
         curl
         -s
         'YOURCOMMAND'
    value_template: >
        {{ value_json.whateverattribute | length }}
    json_attributes:
        - whateverattribute
Any reason to not use the Rest integration, that allows you to define multiple sensors on a single call?
Thanks, guys.
I have no experience at all with the REST integration. I took a look at the RESTful integration and trying to understand.
Does REST replace curl (i.e., curl is no longer used if I used REST)?
Yes. It does exactly the same as a command_line + curl, just more efficiently.
Got it.
I’ve been looking for the equivalent way to reference the JSON number in order to find the LEVEL amount for each entry, and am having a hard time.
Provide the JSON, and we might be able to help.
Thank you. It was included in post 1 but because it has not cr/lf it was easy to miss.
Here it is:
[{“CompanyFillRequestAvailable”:false,“CompanyId”:“29014dc1-acd3-4abe-9e03-0054f48393da”,“CompanyImageId”:null,“CompanyName”:“yyyy Energy Inc.”,“CompanySupportPhoneNumber”:null,“CustomName”:“371”,“DealerId”:“0148e47d-980b-4f4a-bd5c-c835e48c8a02”,“Id”:“c99fd97d-2d7e-437f-a55b-9b4bd46f2701”,“IsOwner”:true,“Latitude”:yyyy1872,“Level”:9,“Longitude”:-xxxxx289,“NotifyAt1”:40.00,“NotifyAt2”:25.00,“NotifyCriticalLevels”:true,“NotifyDispatch”:false,“NotifyDispatchEnabled”:false,“NotifyFillDetection”:true,“Product”:“Propane”,“SensorMaxLevel”:null,“SensorMinLevel”:null,“SerialNumber”:20196761,“TankCapacity”:908.49,“TankFormType”:1,“TankLastPressure”:null,“TankPressureDisplayUnitSymbol”:“kPa”,“TankPrimaryValueType”:0,“ThemeInfo”:null},{“CompanyFillRequestAvailable”:false,“CompanyId”:“29014dc1-acd3-4abe-9e03-0054f48393da”,“CompanyImageId”:null,“CompanyName”:“yyyy Energy Inc.”,“CompanySupportPhoneNumber”:null,“CustomName”:“629”,“DealerId”:“0148e47d-980b-4f4a-bd5c-c835e48c8a02”,“Id”:“236d578d-f835-4e41-8a09-d20a93df50b3”,“IsOwner”:true,“Latitude”:yyyy5841,“Level”:75,“Longitude”:-xxxxx338,“NotifyAt1”:30.00,“NotifyAt2”:20.00,“NotifyCriticalLevels”:true,“NotifyDispatch”:false,“NotifyDispatchEnabled”:false,“NotifyFillDetection”:true,“Product”:“Propane”,“SensorMaxLevel”:null,“SensorMinLevel”:null,“SerialNumber”:20527575,“TankCapacity”:454.24,“TankFormType”:1,“TankLastPressure”:null,“TankPressureDisplayUnitSymbol”:“kPa”,“TankPrimaryValueType”:0,“ThemeInfo”:null},{“CompanyFillRequestAvailable”:false,“CompanyId”:“29014dc1-acd3-4abe-9e03-0054f48393da”,“CompanyImageId”:null,“CompanyName”:“yyyy Energy Inc.”,“CompanySupportPhoneNumber”:null,“CustomName”:“630 Correct”,“DealerId”:“0148e47d-980b-4f4a-bd5c-c835e48c8a02”,“Id”:“a86e10ad-cb5e-449d-a606-ffdae0e1c769”,“IsOwner”:true,“Latitude”:yyyy5976,“Level”:72,“Longitude”:-yyyy9904,“NotifyAt1”:30.00,“NotifyAt2”:20.00,“NotifyCriticalLevels”:true,“NotifyDispatch”:true,“NotifyDispatchEnabled”:false,“NotifyFillDetection”:true,“Product”:“Propane”,“SensorMaxLevel”:null,“SensorMinLevel”:null,“SerialNumber”:24045716,“TankCapacity”:908.49,“TankFormType”:1,“TankLastPressure”:null,“TankPressureDisplayUnitSymbol”:“kPa”,“TankPrimaryValueType”:0,“ThemeInfo”:null},{“CompanyFillRequestAvailable”:false,“CompanyId”:“29014dc1-acd3-4abe-9e03-0054f48393da”,“CompanyImageId”:null,“CompanyName”:“yyyy Energy Inc.”,“CompanySupportPhoneNumber”:null,“CustomName”:“255”,“DealerId”:“0148e47d-980b-4f4a-bd5c-c835e48c8a02”,“Id”:“b9310be9-b276-4294-b09a-11ac67b20cfd”,“IsOwner”:true,“Latitude”:yyyy3741,“Level”:64,“Longitude”:-yyyy3814,“NotifyAt1”:30.00,“NotifyAt2”:20.00,“NotifyCriticalLevels”:true,“NotifyDispatch”:false,“NotifyDispatchEnabled”:false,“NotifyFillDetection”:true,“Product”:“Propane”,“SensorMaxLevel”:null,“SensorMinLevel”:null,“SerialNumber”:24122799,“TankCapacity”:454.24,“TankFormType”:1,“TankLastPressure”:null,“TankPressureDisplayUnitSymbol”:“kPa”,“TankPrimaryValueType”:0,“ThemeInfo”:null},{“CompanyFillRequestAvailable”:false,“CompanyId”:“29014dc1-acd3-4abe-9e03-0054f48393da”,“CompanyImageId”:null,“CompanyName”:“yyyy Energy Inc.”,“CompanySupportPhoneNumber”:null,“CustomName”:“76”,“DealerId”:“0148e47d-980b-4f4a-bd5c-c835e48c8a02”,“Id”:“8f3c2705-39cc-461e-aff5-9251c2eefb5a”,“IsOwner”:true,“Latitude”:yyyy0257,“Level”:72,“Longitude”:-yyyy9472,“NotifyAt1”:30.00,“NotifyAt2”:20.00,“NotifyCriticalLevels”:true,“NotifyDispatch”:true,“NotifyDispatchEnabled”:false,“NotifyFillDetection”:true,“Product”:“Propane”,“SensorMaxLevel”:null,“SensorMinLevel”:null,“SerialNumber”:24470704,“TankCapacity”:454.24,“TankFormType”:1,“TankLastPressure”:null,“TankPressureDisplayUnitSymbol”:“kPa”,“TankPrimaryValueType”:0,“ThemeInfo”:null},{“CompanyFillRequestAvailable”:false,“CompanyId”:“29014dc1-acd3-4abe-9e03-0054f48393da”,“CompanyImageId”:null,“CompanyName”:“yyyy Energy Inc.”,“CompanySupportPhoneNumber”:null,“CustomName”:"125 ",“DealerId”:“0148e47d-980b-4f4a-bd5c-c835e48c8a02”,“Id”:“3c3dcd64-85cc-4961-8489-d210861382ee”,“IsOwner”:true,“Latitude”:yyyy0339,“Level”:75,“Longitude”:-yyyy8042,“NotifyAt1”:30.00,“NotifyAt2”:20.00,“NotifyCriticalLevels”:true,“NotifyDispatch”:true,“NotifyDispatchEnabled”:false,“NotifyFillDetection”:true,“Product”:“Propane”,“SensorMaxLevel”:null,“SensorMinLevel”:null,“SerialNumber”:24554970,“TankCapacity”:454.24,“TankFormType”:1,“TankLastPressure”:null,“TankPressureDisplayUnitSymbol”:“kPa”,“TankPrimaryValueType”:0,“ThemeInfo”:null}]
Sorry, missed it in post 1 (where it was correctly formatted).
I’m on a phone at the moment so testing is trickier. Could you repost, formatted as in post 1, but with the lat/long numbers replaced by 0? Your use of yyyy makes the JSON invalid.
Does this work:
[{"CompanyFillRequestAvailable":false,"CompanyId":"29014dc1-acd3-4abe-9e03-0054f48393da","CompanyImageId":null,"CompanyName":"yyyy Energy Inc.","CompanySupportPhoneNumber":null,"CustomName":"371","DealerId":"0148e47d-980b-4f4a-bd5c-c835e48c8a02","Id":"c99fd97d-2d7e-437f-a55b-9b4bd46f2701","IsOwner":true,"Latitude":0,"Level":9,"Longitude":0,"NotifyAt1":40.00,"NotifyAt2":25.00,"NotifyCriticalLevels":true,"NotifyDispatch":false,"NotifyDispatchEnabled":false,"NotifyFillDetection":true,"Product":"Propane","SensorMaxLevel":null,"SensorMinLevel":null,"SerialNumber":20196761,"TankCapacity":908.49,"TankFormType":1,"TankLastPressure":null,"TankPressureDisplayUnitSymbol":"kPa","TankPrimaryValueType":0,"ThemeInfo":null},{"CompanyFillRequestAvailable":false,"CompanyId":"29014dc1-acd3-4abe-9e03-0054f48393da","CompanyImageId":null,"CompanyName":"yyyy Energy Inc.","CompanySupportPhoneNumber":null,"CustomName":"629","DealerId":"0148e47d-980b-4f4a-bd5c-c835e48c8a02","Id":"236d578d-f835-4e41-8a09-d20a93df50b3","IsOwner":true,"Latitude":0,"Level":75,"Longitude":0,"NotifyAt1":30.00,"NotifyAt2":20.00,"NotifyCriticalLevels":true,"NotifyDispatch":false,"NotifyDispatchEnabled":false,"NotifyFillDetection":true,"Product":"Propane","SensorMaxLevel":null,"SensorMinLevel":null,"SerialNumber":20527575,"TankCapacity":454.24,"TankFormType":1,"TankLastPressure":null,"TankPressureDisplayUnitSymbol":"kPa","TankPrimaryValueType":0,"ThemeInfo":null},{"CompanyFillRequestAvailable":false,"CompanyId":"29014dc1-acd3-4abe-9e03-0054f48393da","CompanyImageId":null,"CompanyName":"yyyy Energy Inc.","CompanySupportPhoneNumber":null,"CustomName":"630  Correct","DealerId":"0148e47d-980b-4f4a-bd5c-c835e48c8a02","Id":"a86e10ad-cb5e-449d-a606-ffdae0e1c769","IsOwner":true,"Latitude":0,"Level":72,"Longitude":-yyyy9904,"NotifyAt1":30.00,"NotifyAt2":20.00,"NotifyCriticalLevels":true,"NotifyDispatch":true,"NotifyDispatchEnabled":false,"NotifyFillDetection":true,"Product":"Propane","SensorMaxLevel":null,"SensorMinLevel":null,"SerialNumber":24045716,"TankCapacity":908.49,"TankFormType":1,"TankLastPressure":null,"TankPressureDisplayUnitSymbol":"kPa","TankPrimaryValueType":0,"ThemeInfo":null},{"CompanyFillRequestAvailable":false,"CompanyId":"29014dc1-acd3-4abe-9e03-0054f48393da","CompanyImageId":null,"CompanyName":"yyyy Energy Inc.","CompanySupportPhoneNumber":null,"CustomName":"255","DealerId":"0148e47d-980b-4f4a-bd5c-c835e48c8a02","Id":"b9310be9-b276-4294-b09a-11ac67b20cfd","IsOwner":true,"Latitude":0,"Level":64,"Longitude":-yyyy3814,"NotifyAt1":30.00,"NotifyAt2":20.00,"NotifyCriticalLevels":true,"NotifyDispatch":false,"NotifyDispatchEnabled":false,"NotifyFillDetection":true,"Product":"Propane","SensorMaxLevel":null,"SensorMinLevel":null,"SerialNumber":24122799,"TankCapacity":454.24,"TankFormType":1,"TankLastPressure":null,"TankPressureDisplayUnitSymbol":"kPa","TankPrimaryValueType":0,"ThemeInfo":null},{"CompanyFillRequestAvailable":false,"CompanyId":"29014dc1-acd3-4abe-9e03-0054f48393da","CompanyImageId":null,"CompanyName":"yyyy Energy Inc.","CompanySupportPhoneNumber":null,"CustomName":"76","DealerId":"0148e47d-980b-4f4a-bd5c-c835e48c8a02","Id":"8f3c2705-39cc-461e-aff5-9251c2eefb5a","IsOwner":true,"Latitude":0,"Level":72,"Longitude":-yyyy9472,"NotifyAt1":30.00,"NotifyAt2":20.00,"NotifyCriticalLevels":true,"NotifyDispatch":true,"NotifyDispatchEnabled":false,"NotifyFillDetection":true,"Product":"Propane","SensorMaxLevel":null,"SensorMinLevel":null,"SerialNumber":24470704,"TankCapacity":454.24,"TankFormType":1,"TankLastPressure":null,"TankPressureDisplayUnitSymbol":"kPa","TankPrimaryValueType":0,"ThemeInfo":null},{"CompanyFillRequestAvailable":false,"CompanyId":"29014dc1-acd3-4abe-9e03-0054f48393da","CompanyImageId":null,"CompanyName":"yyyy Energy Inc.","CompanySupportPhoneNumber":null,"CustomName":"125 ","DealerId":"0148e47d-980b-4f4a-bd5c-c835e48c8a02","Id":"3c3dcd64-85cc-4961-8489-d210861382ee","IsOwner":true,"Latitude":0,"Level":75,"Longitude":-yyyy8042,"NotifyAt1":30.00,"NotifyAt2":20.00,"NotifyCriticalLevels":true,"NotifyDispatch":true,"NotifyDispatchEnabled":false,"NotifyFillDetection":true,"Product":"Propane","SensorMaxLevel":null,"SensorMinLevel":null,"SerialNumber":24554970,"TankCapacity":454.24,"TankFormType":1,"TankLastPressure":null,"TankPressureDisplayUnitSymbol":"kPa","TankPrimaryValueType":0,"ThemeInfo":null}]
You missed a few but I have fixed that. What’s the problem? Your existing value_templates work with that JSON, so something like this at the top level of configuration.yaml and a restart should work:
rest:
  - resource: https://ws.otodatanetwork.com/neevoapp/v1/DataService.svc/GetAllDisplayPropaneDevices
    authentication: basic
    username: "USER"
    password: "PASSWORD"
    scan_interval: 86400
    headers:
      Content-Type: application/json
      - name: "Propane Tank Neevo 371 Gallons"
        value_template: "{{ value_json[0].Level|float(0) *, 2.4 if value_json[0].Level is defined else this.state }}"
        unit_of_measurement: "gal"
      - name: "Propane Tank Neevo 629 Gallons"
and so on. That assumes a) the resource is sending JSON with the correct headers and b) the tanks are always listed in that order.
Wow!
Perfect – and super cool.
Thank you!
