Hi all, new to the forum. My question concerns the need for reed switches (mine have a bare plate on one end and a magnet on the other). I can explain for context. These switches interface with the ratgdo32 disco garage opener, which many people are switching to now for those who want smart garage doors integrated into their whole-home setup. Chamberlin has walled off their MyQ app from any HA integration, forcing people to live inside their walled garden to use their hideous app or move to a device that plays nice with integration. The ratgdo is a worthy replacement. I need reed switches for my setup. Reed switches are a partnership between a magnet and a stationary plate. In my case, I got commercial ones because of the harsh climate where I live. So standard garage door, curved track on both sides. The door is segmented versus one piece. When the door rests in the open position, one part of the switch (a steel alloy mounting plate) sits parallel (not less than 2.5 inches of space) to a magnet that is attached to the garage door. It is my understanding that the mounting bracket and the magnet are (either horizontally or vertically) together to magnetize. That tells the smart opener that the door is open—a similar idea when the door is closed. I had no problem finding an installation area for the reed switch in the closed position. As you can visualize, the door rises with a J bracket in the middle, a plastic piece inside the steel-covered track, and comes to rest. The problem is my motor is well over a foot behind the resting point of the door. I cannot find an area where I can mount these so they magnetize. It can’t be at any angle (45 degrees, for example). Center needs to rest across from center.I am stumped, as structural design is not my strong suit. My garage track is held on either side by a two-by-four that extends from my ceiling. I have mounting hardware for any surface, but still can’t picture a solution in
my head. Help???
