Refactoring Template Switches to Native Light & Fan (ADC Feedback + Pulse Logic)
Hi everyone,
I have successfully “smartified” my kitchen hood using an ESP32 and ESPHome. The hardware side is fully functional and stable.
Hi everyone,
My Setup:
• Control: I use OUTPUT_OPEN_DRAIN on GPIOs to simulate physical button presses (pulsing the button to toggle state).
• Feedback: Since I don’t have clean logic signals, I am reading the voltage of the hood’s LEDs using ADC sensors on the ESP32.
• Logic: If the ADC reads > 2.5V, I know the function is ON.
Current Status:
I have configured everything as switch entities in ESPHome (platform: template). I have 5 switches: Light, Power, Low, Medium, High.
Everything works perfectly: I can control the hood, and the state updates correctly in Home Assistant based on the voltage readings.
The Goal:
I want to clean up my configuration. Instead of having 5 separate switches in Home Assistant, I want to define:
  1. A native Light entity (light).
  2. A native Fan entity (fan) with 3 speeds.
The Problem:
I tried using light: platform: template and fan: platform: template, but I kept running into compilation errors or “Platform not found” issues.
Could someone help me refactor my working Switch YAML into proper Light and Fan templates?
Specific Logic Needed:
• Fan Turn Off Logic: On this specific hood, there is no dedicated “Off” command. To turn the fan OFF, I must simulate a button press on the currently active speed. (e.g., if Speed 2 is ON, pressing button 2 again turns it OFF).
Here is my current working YAML (Switches):
esphome:
  friendly_name: "Hotte Cuisine"
esp32:
  board: esp32dev
  framework:
    type: arduino
logger:
  level: info
api: xxxxxxxx
wifi:
  ssid: !secret wifi_ssid
  fast_connect: true
captive_portal: {}
# 1. LECTURES ANALOGIQUES (ADC1)
  # LIGHT - ORANGE
  - platform: adc
    pin: GPIO36
    attenuation: 12db
    update_interval: 0.1s
    filters:
      - max: { window_size: 10, send_every: 5 }
  # POWER - JAUNE
  - platform: adc
    pin: GPIO32
    attenuation: 12db
    filters:
  # HIGH - VERT
  - platform: adc
    pin: GPIO35
    attenuation: 12db
    filters:
  # MEDIUM - BRUN
  - platform: adc
    pin: GPIO34
    attenuation: 12db
    filters:
  # SLOW - ROUGE
  - platform: adc
    pin: GPIO33
    attenuation: 12db
    filters:
# 2. STATUS LOGIQUES (SEUILS > 2.5V = ON)
binary_sensor:
    internal: true
    lambda: return id(adc_light).state > 2.5;
    filters:
      - delayed_on: 100ms
      - delayed_off: 500ms
    internal: true
    lambda: return id(adc_power).state > 2.5;
    filters:
      - delayed_on: 100ms
    internal: true
    lambda: return id(adc_high).state > 2.5;
    filters:
      - delayed_on: 100ms
    internal: true
    lambda: return id(adc_medium).state > 2.5;
    filters:
      - delayed_on: 100ms
    internal: true
    lambda: return id(adc_slow).state > 2.5;
    filters:
      - delayed_on: 100ms
# 3. ACTIONNEURS (SWITCHS)
switch:
  # --- BOUTONS PHYSIQUES (CACHÉS) ---
  - platform: gpio
    internal: true
    pin:
      number: GPIO23
      mode: OUTPUT_OPEN_DRAIN
      inverted: false
    restore_mode: ALWAYS_ON
  - platform: gpio
    internal: true
    pin:
      number: GPIO18
      inverted: false
  - platform: gpio
    internal: true
    pin:
      number: GPIO19
      inverted: false
  - platform: gpio
    internal: true
    pin:
      number: GPIO21
      inverted: false
  - platform: gpio
    internal: true
    pin:
      number: GPIO22
      inverted: false
  # --- INTERFACE HOME ASSISTANT (SWITCHS VISIBLES) ---
  # LUMIÈRE
    icon: "mdi:lightbulb"
    lambda: return id(status_light).state;
    turn_on_action:
      - if:
          condition: lambda: 'return millis() > 1000;'
          then:
            - switch.turn_off: btn_light_raw
            - delay: 200ms
            - switch.turn_on: btn_light_raw
    turn_off_action:
      - if:
          then:
            - delay: 200ms
  # POWER
    icon: "mdi:power"
    lambda: return id(status_power).state;
    turn_on_action:
      - if:
          then:
            - switch.turn_off: btn_power_raw
            - delay: 200ms
            - switch.turn_on: btn_power_raw
    turn_off_action:
      - if:
          then:
            - delay: 200ms
  # HIGH
    icon: "mdi:fan-plus"
    lambda: return id(status_high).state;
    turn_on_action:
      - if:
          then:
            - switch.turn_off: btn_high_raw
            - delay: 200ms
            - switch.turn_on: btn_high_raw
    turn_off_action:
      - if:
          then:
            - delay: 200ms
  # MEDIUM
    icon: "mdi:fan-speed-2"
    lambda: return id(status_medium).state;
    turn_on_action:
      - if:
          then:
            - switch.turn_off: btn_medium_raw
            - delay: 200ms
            - switch.turn_on: btn_medium_raw
    turn_off_action:
      - if:
          then:
            - delay: 200ms
  # SLOW
    icon: "mdi:fan-speed-1"
    lambda: return id(status_slow).state;
    turn_on_action:
      - if:
          then:
            - switch.turn_off: btn_slow_raw
            - delay: 200ms
            - switch.turn_on: btn_slow_raw
    turn_off_action:
      - if:
          then:
            - delay: 200ms
You can start the cleaning by using analog threshold binary sensor.
and by fixing your description posted twice…
Thanks I will have a look to that and you are right about my description (fixed).
