Hi!
I want to use variable value from other variable with dynamically builded name
This is my case:
variables:
triger1_message: aaaa
triger2_message: bbbb
- variables:
message: '{{ trigger.id ~ "_message" }}'
Currently message
will be triger1_message
or triger2_message
, but I want it to be aaaa
or bbbb
depending on which trigger was triggered…
Please help!
123
(Taras)
March 12, 2022, 4:07pm
2
It appears that what you want to do is to programmatically create the name of a variable using a template like this:
and then get the value of the resulting variable. So if the template produces triger1_message
you want to evaluate it and get its value aaaa
That would require the use of something like python’s eval
function but it doesn’t exist in Home Assistant’s implementation of Jinja2.
Yes, that is what I want to achive…
If this is not possible in way I tried, any other workaround exists?
123
(Taras)
March 12, 2022, 5:34pm
4
Define a dictionary and then lookup trigger.id
in the dictionary to find the matching value.
- variables:
values:
triger1: 'aaaa'
triger2: 'bbbb'
triger3: 'cccc'
message: "{{ values.get(trigger.id, 'unknown') }}"
The following template means:
In the values
dictionary, find the key name provided by trigger.id
and return its value. If there is no matching key name, return unknown
Thanks, it works this way!
