Due to a comedy of errors and a fundamental misunderstanding of how the <<: ! *include*
** syntax works I have flashed a sonoff light switch with no network configuration. No wifi networks and no fallback hotspot. Is it possible to write a new firmware to it in serial mode? I have tried shorting GPIO0
to ground (as I did when originally flashing them) and it didn’t seem to have any effect. Is there any way to convince ESPHome to enter flash mode?
My config I wrote
substitutions:
devicename: light
<<: !include Templates/Single_Switch.yaml
wifi:
networks:
manual_ip:
static_ip: 192.168.88.82
gateway: 192.168.88.1
subnet: 255.255.255.0
** I have the wifi section defined in a common secrets file - I thought that it would inherit the rest of the Wifi config from there as I just wanted to provide a different static IP address.
