Regex to replace instances of `states.*.state` and `states.*.attributes.*`
Find and replace regex for state and attribute template lines
After the creation of a large amount of technical debt in which I kept using long and unpleasant syntax that can trigger errors on loading, I’ve created these two regex find and replace strings to clean up templates in my configuration and lovelace files. I figured folk might find them useful if they’ve found themselves in a similar situation to me.
State
The following regex can be used to find all instances of the discouraged states.sensor.example_sensor.state syntax and replace them with states('sensor.example_sensor') syntax instead.
Find
states\.((?:[a-z]|[A-Z]|_)+\.(?:[a-z]|[A-Z]|[0-9]|_)+)\.state
Replace
states('$1')
Attributes
The following regex can be used to find all instances of the discouraged states.sensor.example_sensor.attributes.example_attribute syntax and replace them with state_attr('sensor.example_sensor', 'example_attribute') syntax instead.
Find
states\.((?:[a-z]|[A-Z]|_)+\.(?:[a-z]|[A-Z]|[0-9]|_)+)\.attributes\.((?:[a-z]|[A-Z]|[0-9]|_)+)
Replace
state_attr('$1', '$2')
