often I get this one in rejseplanen (unknown) — too slow update ? can it be fixed?
I know that this is a year old, but I have the same issue, and also found out why.
The API from “Rejseplanen” only shows the next 20 departures from a given ID (stop), so if there is more than 20 departures between the ones that you whant, then you will get the “unknown” until there is less than 20 departures to your next one.
I have spoken to the “Rejseplan” API team, and they have given me another link than used in this integration.
im working in København and would like to only see departures for Holbæk:
http://xmlopen.rejseplanen.dk/bin/rest.exe/departureBoard?id=8698626&direction=8600719
This calls for both the stop ID(hvere you wanna go from) and direction ID(where you wanna go to) and now you only gets this departures.
Unfortually the integration only supports direction by name and not ID.
It would will help if we could choose between “direction_name” or “direction_ID”
thanks - i will try it !
I’m affected by the same limitation – transport hubs don’t work well with this integration.
