Related links open in browser
Hi guys, this is the first time I’m writing here, because I have a problem and I don’t understand it, I don’t know if it’s a fault of the HAOS companion app or it’s something on my part.
Since the last updates, HAOS, but also as I reinforced certain security elements in my Cloudflare tunnel, it could come from here, but I don’t know how to verify it.
It turns out that if I enter a device in my HA dashboard, click on the three dots, go to related or visit the page of that device and go to automations, those automations, their editing (just like if you go through settings > automations), instead of opening in the HA companion app, they open in the browser (Chrome in this case).
I can’t understand this behavior, and even more so when it doesn’t happen with Scripts!.
And yes, before you ask, I have checked the configuration, the compatible links that the HA app opens are set to open with the application.
Let’s see if anyone has this problem or knows where the problem might be because it’s quite annoying for everyday use, editing your cars, etc.
It happens to me on all devices, two tablets (Samsung and Xiaomi as well as my Pixel 7)
I also have this problem but I am using the Home Assistant Docker container (not HAOS) and I am just using NPM for a reverse proxy; I don’t have CloudFlare or other things in between.
I also checked that HA was set to open links by default. For what it’s worth I’m fairly certain this worked properly for me for a previous version of HA/the app.
It seems that they have fixed it in the latest update of HAOS, today I updated and I just tried and it doesn’t happen anymore, v15.
