I have TYWRA-RF flashed with Esphome.
TYWRA-RF is WIFI relay with one relay (connected to P24 of CB3S) and two buttons (connected to P14 and P6 of CB3S).
I am going to connect the relay to a door button switch. The door button switch opens the sliding door by a short press and the door closes automatically after some time.
When I want to keep the door open, I just keep on pressing the door button switch. The door closes automatically when the door button switch is released.
In order to emulate such behavior of the door and the door button switch with TYWRA-RF, the two buttons and one relay should work like below.
Physical button 1: when pressed, the relay is turned on for 1 second and then automatically turned off (emulates a short press of the door button switch).
Physical button 2: when pressed, the relay is turned on until button 2 is pressed again (emulates long press of the door button switch).
With my code, button 2 turns on the relay on the first press but does not turn off the relay on the second press whereas button 1 works as intended (the relay is automatically turned off after 1 second).
When I press GUI button 2 at the frontend (Home Assistant or web), the relay is turned on but the GUI button 2 turns itself off after about 1 second (the relay stays on).
I cannot figure out what is wrong with my code. Any help would be appreciated.
Here is my code.
esphome:
friendly_name: TYWRA-RF
bk72xx:
board: wb3s
logger:
web_server:
captive_portal:
mdns:
api:
ota:
- platform: web_server
- platform: esphome
wifi:
networks:
- ssid: !secret wifi_ssid1
password: !secret wifi_password1
binary_sensor:
- platform: gpio
pin:
number: P14
inverted: true
mode: INPUT_PULLUP
on_press:
then:
- switch.toggle: door_open
- platform: gpio
pin:
number: P6
inverted: true
mode: INPUT_PULLUP
on_press:
then:
- switch.toggle: door_open_n_hold
output:
- platform: gpio
pin:
number: P24
inverted: false
switch:
turn_on_action:
- script.execute: pulsetime
turn_off_action:
- script.stop: pulsetime
name: Door open and hold
turn_on_action:
- output.turn_on: door_relay
turn_off_action:
- output.turn_off: door_relay
script:
- id: pulsetime
then:
- delay: 1s
- switch.turn_off: door_open
