Relay I/O board with Ethernet connection
Hi !
I’m searchin a relay board mit e.g. 8 or 16 outputs and inputs to control some devices in m house.
I found the following two:
https://de.aliexpress.com/item/1005003736312354.html
https://de.aliexpress.com/item/1005005470473213.html
Did someone already use them with Home assistant ?
what are the real differences (the second one has bigger relays, but in the end I only want to switch signals and no load.
Which one would you recommend?
Also suitable would be 2 boards with 6 or 8 in/outputs each.
Are there other ways than aliexpress or alibaba to buy them ?
Or are there similar alternative which can be bought on the european market directly ?
Best regards
Karl
