Relay triggering with physical potentiometer and dht sensor
Hello;
I just joined the homeasistant family and am stuck in automation. What I want to do is to trigger the relay if the potentiometer data is lower than the dht data. If it is larger than dht data, it will close. I can’t understand syntax operations. Please don’t laugh, I’m just getting started…
thank you:)
Welcome to the HA world!
Here is a rough start for you:
alias: relay control
  - platform: numeric_state
    entity_id: sensor.POTENTIOMETER
    below: sensor.DHT
    above: sensor.DHT
  - choose:
      - conditions:
          condition: trigger
        sequence:
          - service: switch.turn_off
            entity_id: switch.RELAY
      - conditions:
          condition: trigger
        sequence:
          - service: switch.turn_on
Change the entity ID’s I left in UPPERCASE to your actual ones (use lowercase).
Another way could be:
  - service: >
      switch.turn_{{'off' if states('sensor.POTENTIOMETER') <= states('sensor.DHT')  else 'on'}}
hello spark;
I am grateful to you for your answer. I didn’t believe it when my friends who used home assistants said that the community helped. You have renewed my faith :slight_smile:
By the way, which ymal file will I add them to?
would that be effective, dave?
If it’s effective, I’d like to base the logic on it.
Hang on… I’m just updating my post because I thought of a different way to do it… hold tight while I fix all the copy / paste mess!
Hopefully my edit is correct now… The first version uses ‘simple’ automation code (easy to read and understand what is going on) whereas the second one uses a template which is (in my mind) more difficult to do. This template is fairly easy but some templates are crazy and I always need help to get them working.
dear dave;
Where or in which ymal file will I write this automation code? by the way i declare you hassio my best friend for helping me when i was just getting started :slight_smile:
You can actually do these via the automations editor GUI. That would be easiest for a beginner
Thank’s dave
