I’m trying to use this with an S34U18 without success.
I enabled UART debug/lambda and all data I get looks like this:
- lambda: |-
UARTDebug::log_string(direction, bytes, debug_prefix);
std::string str(bytes.begin(), bytes.end());
id(rawString).publish_state(str.c_str());
\x03\xFE\x00\x00\xF8\x00\x90\xFD\x00\x00\x00\xF8\x00\x00\xFC\x01\xFF\xE9\x00\x00\xFC\x00\x00\xA8\x00\xFC\x00\x00\x00\xFC\x00\xC0\xFA\x00\xFF\x00\x00\xFF\x00@\xF3\xFF\x00\xFF\xBD\b\x00\xFE\x01\x80\xF3\x00\xFF\b\x00\x00\xFC\x00\x04\xE0\x00\xFEi\x00\xFE\x01\x10\xB4\x00\xFFS\x00\x00\xDF\x00\x80\xFA\x00\xFE\x03\x01\x00\xFE\x00\x00\xC2\x00\xFF\x02\x00\xFC\x00\x00\xEA\x00\xF8\x05\x00\xD0\x00\x00\xD0\x00\xFE\xF7\x05\x02\xFF\x01\x00\x00\xF8\x00\xFE\e\x00\x00\xFC\x00@x\x00\x
Is this correct? Or should the data be received as clear text?
This is the log from the application:
[19:16:46][V][dsmr_custom:299]: Starting P1 port read attempt (no request pin).
[19:16:47][V][dsmr_custom:337]: Header of plain telegram found ('/').
[19:16:56][V][dsmr_custom:373]: Footer of plain telegram found ('!'). Expecting CRC and newline.
[19:16:57][V][dsmr_custom:373]: Footer of plain telegram found ('!'). Expecting CRC and newline.
[19:16:58][V][dsmr_custom:378]: End of plain telegram detected (newline after CRC). Length: 4925
[19:16:58][V][dsmr_custom:693]: Attempting to parse P1 telegram of 4925 bytes using vendored parser.
[19:16:58][W][dsmr_custom:717]: DSMR P1 vendored parser error:
[19:16:58][V][dsmr_custom:726]: Processing telegram for custom OBIS sensors line by line.
[19:16:58][V][text_sensor:035]: 'debug telegram': Received new state /
[19:16:58][D][text_sensor:120]: 'debug telegram' >> '/'
[19:16:58][I][telegram_dump:429]: --- FULL TELEGRAM RECEIVED ---
