I’m new here and recently started using Home Assistant. Now I’m looking for a smart thermostat that works really good with it.
I saw a lot of recommendations online, but many reviews are mixed and I’m not sure which one is actually reliable for everyday use. I would like something with local control if possible and easy to set up.
What are you using and would you recommend it? Thanks for the help.
What to use you fav temperature sensor ? , and basically configure your Thermostat any way you want, with i.e additional automations etc. Use Generic Thermostat - Home Assistant .
The OP asked for local control - the generic thermostat doesn’t offer that.
To be clear I think the generic thermostat is the best solution for a lot of problems, but if the OP needs local control they would be better off with physical hardware.
Then there are the standard disclaimers that if you use a physical thermostat it will continue to work even if HA is down.
As OP want it in HA, Generic Thermostat is indeed Local, If you get a Power cut, No Brands thermostats will work either, Same as if the WIFI/Router or internet “clocks out” , etc.
Yes all Automations have it’s “pitfalls” , And the only time my HA’s been down is either because i took it down, or do to Power Cuts outside my control
( Which could have been avoided with a UPS, for HA, and i.e (circulation pump " if it’s waterheated ) and the thermometers runs on battery(over zigbee)
