I have a program that generates an MQTT message once a minute, or more often if the signal it is monitoring moves quickly. I configured this signal as a sensor in HA and it works great, use it to trigger an automation no problem.
The issue I have is: sometimes if there is a problem with the network, my program stops publishing - it’s still running, apparently it doesn’t think there’s a problem, but no more sensor updates reach HA. Now, I have a restart script that pkills the existing process and relaunches it, and when that is done it reconnects to mosquitto and everything is good again.
What I would like to have is a trigger in HA that notices that no data has been received from the sensor in, say, 5 minutes, and at that point fire the command to run the restart script. I have seen references to triggering on every sensor data point received and starting the actions with a delay which will restart every time a new data point is received. For whatever reasons, this approach has been unreliable for me.
Is there anything else that will reliably trigger an automation based on a missing “heartbeat” sensor signal?
Not publishing or not receiving?
Use MQTT Explorer to verify that the device is publishing the message or not. There is an add-on for MQTT Explorer, but I recommend that you install it on your computer separate from Home Assistant.
The sensor generates data from 0.0 → 100.0 values over 10.0 trigger an automation. I suppose, since I have control of the sensor publishing code, I could send -1.0 for the LWT, but that seems… clumsy.
