I’m already using the Home Connect (Bosch) integration for a while and suddenly it stopped refreshing the correct states. I found out that, when I manually reload the integration the states become active and polling again. To patch this situation, I’m currently using the following automation to reload the integration when my (Shelly) Power Plug is changing states.
alias: 🤖 Automation - Reload Home Connect Integration
description: >
Reload Home Connect integration when the washing machine or dryer starts based
on Shelly plug power usage.
triggers:
- entity_id: sensor.shellyplug_power
above: 0
trigger: numeric_state
actions:
- data:
entry_id: <CORRECT ID FROM .storage>config file
action: homeassistant.reload_config_entry
- data:
message: Home Connect integration has been reloaded due to appliance activity.
action: notify.mobile_phone
mode: single
I’m receiving the notification correctly when the power plug states are updated, but my Home Connect integration is not being reloaded. What am I doing wrong?
