Remember dimmer level (Qubino, Z-wave)
I’m using Qubinos Flush Dimmers (Z-wave) with HASS. I have one issue which is that when I turn on the dimmer/light from HASS the brightness is always set to full level. It will not remember the brightness level. Is there any solution to solve this? I would like HASS to turn on the dimmer at the brightness level it was when turned off.
When I’m using the wall switch it works as wanted, remembering the last dim-level.
I’ve reported this as a bug…
