Remootio garage door automation - new product
Hi all - I got the peaceduck custom integration working fine with my Remootio. It’s been solid for a week and through a couple of HA core updates as well. Thanks for this integration.
Where I can just change IP ? Or do I need add again device ?
My API is same I just need to change IP because my IP is changed.
I can’t find option in Remootio how to set static IP :frowning:
I am using peaceduck Remootio integration - working great on last update.
Hi all, does anyone have a solution to this particular issue please? @peaceduck
My integration was working well for a couple of months but one door kept failing to connect to HA this weekend. Therefore, I removed both Remootio devices from HA and removed the integration from HACS in the hope that re-installing and re-adding both devices would fix the issue. However, I now can’t add any of my devices due to the error in the thread below:
Disregard the above, I have fixed it. The Remootio app was giving me the wrong IP address. I found the correct IP in my routers settings.
I would like to know how. I have re-installed the integration but still the same error… I also checked the IP address…
Hey guys, I’m not sure what is wrong with me but i couldn’t get any of these options working for me, My issue with the default Remootio app is that the door open notifications are too quiet, and laggy, so I decided to create my own. I’s a manuall process to setup but it works, and you can control the opening and closing. “Complete Home Assistant integration for Remootio garage door controllers with advanced monitoring, multi-channel alerts, and automation capabilities.” the code is here at GitHub - rowds15/remootio: Remootio Home Assistant Integration. Clone it to suite you needs. enjoy.
Please has anyone managed to modify the Remootio integration so that it has an option to hold the gate open for a period of time, mirroring that same feature on the Android app for phones?
I’ve updated my manual config to full integration. download via HACS
GitHub - rowds15/remootio: Remootio Home Assistant Integration with the ability to control both relays. Give it a go
Im currently using yours alongside Smartthings remootio for testing @rowds15
Is there a way to get the ‘opening’ and ‘closing’ states as i want to use these on my dashboard. Currently i only get ‘open’ and ‘closed’ statuses
I don’t believe so, the sensor is either open or closed
