Remote access to the dashboard …
Not sure this is the correct category but
I have a network/dashboard issue.
I have remote access to ha via Cloudflare
My default dashboard is a series of card which lead to other cards
So “default” to “lights”. - ‘default to Waste Collection”,
Weather, Velux etc and a return button to get back to default.
If I operate the function locally everything works as expected.
If I operate remotely nothing works. If I hold the buttonit does not display anything politely advising the is no entity configured - which is correct
What is configured is the “navigate on tap” function which navigates to the dashboard via the local identifier. “Http://192.168.x.y/waste-dashboard/0”
So while I can eccess the ha instance top level page remotely - I dont get access to a subordinate page -
I can access them if I try off the sidebar menu.
Is there a way I can access the subordinate pages remotely. My (failing) memory seems to think this DID work then stopped -so this may be down to tinkering perhaps with Cloudflare but several hours of searching has so far failed to spot an error
Has anyone out there successfully got remote access to a subordinate dashboard ?
for external use you will need https://
So, your navigation in HA contains the whole link? Meaning, it has the HTTP://…?
Just use the path. Then, it will use the original webpage from either internal or external and append it.
/waste-dashboard/0
Mmmm. Cloudflare automatically convert http to https ……. But I’ll change it and see ….
Come here till I kiss you !!
That works ….
