Hello everybody.
I am working in yaml mode and at home I work by ssh.
The problem I have is that I cannot do nat from my router. It could only access through port 80 I think.
Is there a way to access the files to be modified remotely?
Thanks for the help. I have the system installed on a raspberry. It is a virtual environment. It is not installed with hassio that is why the file editor does not appear. The problem is that I don’t have the rapsbian desktop installed either. Sorry for the translation. Hope it’s understandable
I suppose you mean port forwarding or… ?
NAT is for internal to external, not the other way around.
You’d better be sure, but that’d be surprising. Generally, ISP specifically close those 80/443/25 ports for security reasons, but allow the other ones.
Thanks. I have the system in yaml mode. Now I can no longer edit the files from Home assistant. The problem is that I have no way to get in from the outside because the modem doesn’t have that option. The only thing left is to put a router afterwards. So I wanted to know if there is any integration that allows me to modify remotely. Or some way that I do not know.
Sorry @tom_l, just earned my "Read the Guidelines’ badge looking for the language restriction of the forum, found it it the FAQ.
I will translate what he is saying, he tried in English but was not clear. I’ll try to translate his message:
Haha, thanks. I have the system in YAML mode. Now I can’t edit files from Home Assistant. The problem is that I don’t have a way to login login/use it/enter from outside because the modem doesn’t have that option. My only option is to setup a router later. That’s why I wanted to now if there’s some kind of integration that allows me to edit remotely. Or some other way I don’t now.
Thanks.
Sorry, it’s not even clear in Spanish either.
I don’t know what you mean that the system is in YAML mode, you mean you can’t access the home assistant website?
I’m pretty sure that if you can’t forward ports in your router, there’s now way you can directly access the network from outside.
You could remotely access a computer already inside your network running anydesk, teamviewer, google remote desktop, they don’t usually rely on port forwarding, and from there ssh to your HA host.
You said you can access your server from nabu casa, if you are getting to the UI, you could install Terminal and SSH add-on, it allows you to open a terminal on the web browser, or install File Editor add-on, which allows you to edit files. (But I think you said you can’t access)
Nabu Casa does not require port forwarding. Neither does setting up a VPN or ZeroTier.
Another option might be to use AnyDesk (free for personal use) to RDP to a PC on the local network and configure from there. It’s pretty seamless, very easy to set up and has mobile clients for iOS and Android. This is my backup access.
