Which Zigbee or Matter remote control is best suited for use with Home Assistant to control a Philips Ensis (which actually consists of two LED strips)?
I would like to be able to at least: switch the light on and off, adjust the brightness, change the scene, and if possible, change the color of one of the two strips.
Thanks.
If you’re using Zigbee2MQTT, pick one you like from here.
For any other Zigbee integration, have a look here.
Sorry, couldn’t filter out remote scene switches, though those would also work
Thanks, it could be a good start, but I have a STYRBAR remote, which is on this list, and I’m having some problems binding groups : I had to downgrade the firmware, but there are still many malfunctions.
