Ih8rain2
(Ed)
December 26, 2025, 11:46pm
1
Hi
I have 2 instances connection with a custom component Remote_HomeAssistant.
The setup works perfectly fine. The only thing I can’t get working is a live stream camera in the remote instances to appear in the main instance.
With Generic Camera integration I have a RSTP camera working without issues but I can’t get the view in the main instances.
I have set load_components - camera in the remote instance config.yaml but it doesn’t help.
In fact I am not sure where to look. Any ideas?
IOT7712
December 26, 2025, 11:57pm
2
Obviously not!
Any network configuration issues?
Describe your network, camera IP addresses, HomeAssistant IP address, and how they are supposed to communicate.
Post the yaml and logs [properly formatted]
Ih8rain2
(Ed)
December 27, 2025, 12:22am
3
No network config issues. The instances are connected with a Tailscale setup.
In the remote instances I use a Sonoff IP camera icw the generic camera integration to create a camera entity with a live stream. Works fine on the remote instance. Clear picture.
The same entity appears in the main instance but doesn’t give a live stream.
jeffcrum
(Jeff Crum)
December 27, 2025, 4:24pm
4
Try the webrtc-camera card. I am using custom one from HACS. But, I think there is one in HA now.
Ih8rain2
(Ed)
January 10, 2026, 2:44pm
5
I gave HA remote a good consideration but decided to split it again. Solves a lot of issues.
