Hey, guys,
I’m facing a challenge that’s been going on for a week now.
I’m going to replace the board that controls the garage door motor with a board that I have more control over using HA and Node-red. For this I chose this board, as it already has inputs for a 433Mhz RF receiver and transmitter: https://bit.ly/46QLSzg
Using Esphome I made all the logic I need to work.
However, I have come across a problem that is keeping me up at night.
I don’t know how to add the codes for the other 6 controls in the house.
This without me having to repeat the entire button code 6 times. I believe there is a clean way to do this.
For example:
rc_switch_raw:
code: '110100001001010111100100101' //code control A
protocol: 6
rc_switch_raw:
code: '2101000001001010111100100101' //B code control
protocol: 6
rc_switch_raw:
code: '3101000001001010111100100101' //C code control
protocol: 6
rc_switch_raw:
code: '4101000001001010111100100101' //D code control
protocol: 6
Below is the code in question.
esphome:
platform: ESP32
board: esp32dev
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
ota:
password: "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
wifi:
ssid: "STARLINK"
password: !secret passWordWifi
manual_ip:
static_ip: 192.168.88.88
gateway: 192.168.88.88
subnet: 255.255.255.0
ap:
ssid: "Kc-868-A4-Garagem"
password: "8888888888888888"
captive_portal:
########### WEB SERVER #######################
web_server:
port: 80
############ REMOTE_RECEIVER #################
remote_receiver:
# - id: rc_receiver
pin:
number: GPIO19
inverted: False
dump:
- rc_switch
tolerance: 35%
filter: 250us
idle: 4ms
buffer_size: 2kb
########## REMOTE_TRANSMITTER ###############
remote_transmitter:
pin: 21
# RF uses a 100% carrier signal
carrier_duty_percent: 100%
########### SWITCHS ###########################
switch:
########### PORTÃO GARAGEM ###########
- platform: gpio
pin: GPIO2
restore_mode: ALWAYS_OFF
interlock: [close_switch]
- platform: gpio
pin: GPIO15
interlock: [open_switch]
########### CAPACITOR #################
- platform: gpio
pin: GPIO18
inverted: False
icon: "mdi:engine"
################ GLOBAL VARIABLES ##############
globals:
- id: state_gate
type: std::string
initial_value: '"off"'
############### SENSOR BINARY #######################
binary_sensor:
############## OPEN BUTTON ##########################
- platform: remote_receiver
on_press:
################## DISABLE CAPACITOR PER 950ms
- then:
- if:
condition:
lambda: 'return id(state_gate) == "off";'
then:
- switch.turn_off: in_capacitor
- delay: 2000ms
- switch.turn_on: in_capacitor
else:
- logger.log: ' ATTENTION, THIS IS A TEST'
################## STARTS OPENING
- then:
- if:
condition:
then:
- lambda: 'id(state_gate) = "on";'
- switch.turn_off: close_switch
- switch.turn_on: open_switch
- delay: 9.5s
- delay: 2000ms
- switch.turn_off: open_switch
- binary_sensor.template.publish:
state: on
else:
- logger.log: 'ATTENTION, THIS IS A TEST'
rc_switch_raw:
code: '1101000001001010111100010101'
protocol: 6
############### CLOSED BUTTON ###################
on_press:
################## DISABLE THE CAPACITOR PER 950ms
- then:
- if:
condition:
lambda: 'return id(state_gate) == "on";'
then:
- delay: 2000ms
else:
################## INICIA A ABERTURA
- then:
- if:
condition:
then:
- lambda: 'id(state_gate) = "off";'
- switch.turn_on: close_switch
- delay: 11s
- delay: 1000ms
state: off
else:
rc_switch_raw:
code: '1101000001001010111100100101'
protocol: 6
