dskudrin Thanks so much for the drivers - there’s a few there I’ll need. I’m trying out the RTI to HA communication too, but the info here should get me started. One ask - do you happen to have a firmware file for a XP6 that works with Integration Designer 9? The Sonos driver only works with newer firmware, but I can’t tell what version it actually requires. Or I could find an older Sonos Driver, which I had but it didn’t seem to work any more.
Hi. I haven’t worked with ID9 — I started directly with ID11. Honestly, I would move the project to ID11, since it’s easier and more convenient to work with. A few video tutorials were enough for me to write my own project in it.
As for the XP-6 firmware, I only had this processor for testing once, and I downloaded firmware version 24.3.29 from mid-2024. Unfortunately, the RTI website doesn’t provide access to the firmware archive, but if you decide on the required version, it can be found. I’m attaching a description of the firmware version changes.
And btw, XP-6 firmware version 2.0.7 can be downloaded from RTI website (mid-2019)
RTI XP6 Firmware Version 24.3.29
Summary
VERIFYING THAT YOU NEED THE UPGRADE
If you already have version 24.3.29 or newer you should not upgrade your
firmware to this version. Use the “Get Firmware Version” command from
the Communications menu in TheaterTouch Designer or Integration Designer
to determine the current firmware version. The reported version number
will consist of a number followed by a bootloader version number
[for example: 24.3.29 (Bootloader: 1.5)]. If the first part of the reported
version number is 24.3.29 or higher, you do not need this update.PREREQUISITES FOR USING THIS UPGRADE PROCEDURE
TheaterTouch Designer 3.0 or higher, or Integration Designer 6.0 or
higher must already be installed on the PC that you wish to use to
upgrade the XP6 firmware. If your PC runs a 64-bit version of Windows,
Integration Designer 7.0 must be installed to perform the upgrade.
Upgrading to the latest version of Integration Designer is strongly
recommended. You should verify that you can communicate with the XP6
using Integration Designer before attempting to upgrade the firmware.FIRMWARE UPGRADE PROCEDURE
- Connect power to the XP6 and make sure it operates normally.
- Make sure Integration Designer 6.0 or higher is installed on the
PC that you are using to update the XP6 firmware, and that Integration
Designer can communicate successfully with the XP6. You can use the
“Get Firmware Version” command on the Communications menu in Integration
Designer to verify that the USB communications are working properly.- Run the .exe program contained in this ZIP file and follow
the on-screen instructions carefully.LIST OF CHANGES IN THIS RELEASE (RELEASE 24.3.29)
- Added support for Alexa
- Added optional UDP OnError callback
- Fixed crash caused by Ping object
- Prevent drivers from delaying system shutdown excessively
- Fixed HTTPServer object that could truncating data from slow clients
- Fixed remote access connection issue
LIST OF CHANGES IN RELEASE 23.11.16
- Add support for cloud remote access
- Fix bug that could cause OAuth drivers to fail to refresh their tokens
LIST OF CHANGES IN RELEASE 23.5.11
- Fixed memory leak
LIST OF CHANGES IN RELEASE 23.3.28
Speed up SysVar subscription code.
Added JavaScript warning to HTTP.Open() if object is already open.
Fixed RTIPanel issue where the two-way scrolling list would be missing items if more than 10 devices are available (iOS/Android).
Fixed a memory ownership problem affecting gargage collection in callback functions for HTTPServer, TCPServer, Serial, SSH, MulticastUDP and MQTT objects.
Added OAuth driver support.
Part of this update adds the ability to launch an OAuth dashboard from your processor. This means that multiple drivers need to share port 80.
To support this, a new version of the XP Diagnostic driver is required if you wish to continue using it on port 80.
This is available via the driver store or from within Integration Designer.LIST OF CHANGES IN RELEASE 21.9.13
- Fixed bug that could cause HTTP communications from the processor to fail
- Fixed bug that could crash the processor if a driver passed an empty string
as a dynamic image URL.- Fixed bug that could cause SSH handshake to fail.
- Fixed bug that could truncate SSH fingerprint data.
- Added keyboard-interactive authentication support to the SSH object
- Added multicast DNS discovery support for drivers
- Add a callback to notify drivers when a websocket receives a PING message
- Update mbedTLS to the latest version
LIST OF CHANGES IN RELEASE 21.01.27
- Fixed a bug that prevented Zigbee communications from working after firmware upgrade
LIST OF CHANGES IN RELEASE 20.11.20
- Preserve the system name during firmware upgrades.
- Added support for SSH connections from drivers.
- Fixed a bug that could cause drivers to calculate MD5 hashes incorrectly.
- Fixed a bug that prevented reboots during network firmware upgrades or from RTiQ.
LIST OF CHANGES IN RELEASE 20.8.25
- Improved reliability of the system file downloads and firmware upgrades
- Improved network reliability in certain environments
- Driver API changes:
- Fixed StartSSLHandshake timing out with slow web servers
- Fixed WebsocketUpgrade failure in certain cases
- Fixed parseInt failure in certain cases
- Fixed floating-point math precision
- Improved overall system performance
LIST OF CHANGES IN RELEASE 20.2.28
- Misc. ZigBee modifications related to firmware & feedback
- Updated application to support VXP-82 terminology
- Overall system performance updates
LIST OF CHANGES IN RELEASE 2.0.7
- Improved reliability of Zigbee communications.
- Improved reliability of Firmware Updates and System Downloads.
- Fixed firmware updates from computers with multiple network adapters.
- Fixed hang on start with the Ethernet cable unplugged.
- Improved DHCP and Static network configuration setup.
- Driver API updates.
- Updated TLS support.
- Fixed issue with Samsung TV driver.
- Enabled using XP-6s as an expansion processor.
- Fixes to using VIP-1 as expansion device.
- Emabled support for new hardware versions.
LIST OF CHANGES IN RELEASE 1.16.18
- Added RTiQ support
- Added VIP-1 expansion device support
- Fixed SSL related issues
- General stability improvements
LIST OF CHANGES IN RELEASE 1.15.3
- Improved SSL Compatibility
LIST OF CHANGES IN RELEASE 1.14.4
- RTiPanel license changes (unlimited and floating licenses)
LIST OF CHANGES IN RELEASE 1.13.26
- Misc. fixes to prevent memory leaks
- Improved tools to help debug memory related issues
- Fix for issue with macro time range test using minutes before sunrise or sunset
- Increased NTP clock updates to every 12 hours to improve clock accuracy
- Increased maximum drivers allowed in the Diagnostics Driver from 40 to 80
- Fix for issue with nested macros containing no steps causing instability
- Fix for issue with systems with more than 50 drivers causing instability
- Fix for remote finder / wakeup causing lockups when the remote is not found
LIST OF CHANGES IN RELEASE 1.12.15
- Added WK2 support
- Zigbee stability improvements
LIST OF CHANGES IN RELEASE 1.11.2
- Fix for low memory issues caused by unresponsive devices
- Fix for diagnostics driver Sysvars page crash when the driver contains many sysvars
LIST OF CHANGES IN RELEASE 1.10.6
- Fix for incorrect free space calculations when downloading
- Fix for rs-485 communications issue when the processor is the 2nd slave
LIST OF CHANGES IN RELEASE 1.9.4
- Added Zigbee wakeup for download support (for devices that support wakeup via Zigbee)
LIST OF CHANGES IN RELEASE 1.8.8
- Added support for RCM-4.
- Added support for Master/Slave configurations.
- Added support for Zigbee/RS485 sub-networks.
- Added support for XP Diagnostics driver.
- Driver API version 11:
- Added logging APIs (System.LogInfo, System.LogEerror, System.LogLevel, System.GetViewName).
- Fixed issue where persistence data is lost after removing another driver.
- Fixed issue where comm.Read can consume all system resources.
LIST OF CHANGES IN RELEASE 1.7.9
- Added support for PCM-4.
- Added shutdown watchdog for cases when a rogue driver has locked up system.
- Changed system initialization to wait for expansion devices before starting drivers.
- Driver API version 10:
- Added support for non-UPnP UDP multicast addresses.
- Added SSL handshaking to HTTP object.
- Added System.GetRandomInteger
- Fix for Surfir ignoring zone code when used in 433 mode.
- Fix for status LED not lighting for serial and driver commands.
- Fix for files being left in temp directory after download.
LIST OF CHANGES IN RELEASE 1.6
- Driver API update (Version 9) This release includes UPnP support along with other upgrades and improvements.
- Added support for Surfir remote.
- Added support for datafile timezone information.
- Updated built-in timezone data through June, 2012.
- Fix for long wake-up delay when connectin with RTiPanel products.
- Fix for remote beep not working on Virtual Panel.
- Fix for IR output sustain not working when using some Samsung codes.
- Fix for processor lockup when switching to daylight savings time.
- Fix for one-way serial strings causing drivers to stop working when using the same port.
LIST OF CHANGES IN RELEASE 1.5
- No changes, this was an internal release.
LIST OF CHANGES IN RELEASE 1.4
- Fix for driver API memory leak. This would manifest itself as a locked-up processor.
LIST OF CHANGES IN RELEASE 1.3
- Support for RTiPanel for Android.
- Support for ESC-2.
- Support for XP to XP macro trigger.
- Support for iPad3.
- Fix for driver command string parameter limit of 128 chars.
- Fix for driver config string limit of 255 chars.
- Fix for RTiPanel configuration corruption when certain sounds files used.
- Fix for RTiPanel files not being deleted when programming changes.
LIST OF CHANGES IN RELEASE 1.2
- Fix for serial port baud rates < 1200 not working.
- Fix for timezone not changing until processor is reset.
- Virtual Panel remote page flips not working.
- Fix for lock-up when processor is used as gateway in multi-processor configuration.
- Fix for driver javascript files that contain a UTF signature.
- Fix for Virtual Panel sustain not working when using internet as output mode.
- Increased driver TCP write limit.
- Fix for memory leak when using driver events.
- Reduced driver send latency when using TCP connection.
- RTiPanel support.
- Fix for certain timezones causing the system not to operate.
