Remove entity in error
I have some history_stats entities that are in error and I can’t remove them. Do you have an idea how to proceed ?
Capture d’écran du 2024-12-03 12-51-46
Hi, have you searched the forum?
https://community.home-assistant.io/search?q=delete+entities
sure, but not found an answer yet
https://community.home-assistant.io/search?q=history_stats+delete
I feel stupid.
Thanks a lot.
So, did you solve it?
Yes, with http://haos_url/config/integrations/integration/history_stats
Ok, good you got it solved.
The proper link for that integration: History Stats - Home Assistant
Please mark the post with the answer that helped you as the solution so anyone who’s searching for this can benefit from it.
You do that by selecting the three dots under the post:
Then select the check box:
Also, by doing so this prevents that someone else steps in for trying to help.
