!remove example from documentation fails when using substitutions
I’m trying to understand how !remove is supposed to work.
To do so, I reproduced exactly the example from the ESPHome documentation:
But the example does not work.
I created a file switch.yaml:
switch:
  - platform: restart
    name: "Living Room Restart"
Then test.yaml:
esphome:
packages: !include switch.yaml  # see above
esp32:
  board: wt32-eth01
  framework:
    type: esp-idf
substitutions:
  disable_reboot: true
switch:
  - id: !remove ${disable_reboot and 'restart_switch'}
I have this error:
Failed config
switch.unknown: [source test.yaml:23]
  Source for removal of ID 'restart_switch' was not found.
  id: !remove restart_switch
If I use the id without any substitution:
switch:
  - id: !remove restart_switch
It works.
Moreover, I dont see how not to remove the switch with this mechanism.
I tried:
substitutions:
  disable_reboot: false
switch:
I got:
  Source for removal of ID 'False' was not found.
I tried:
substitutions:
  disable_reboot:
switch:
I got:
  Source for removal of ID 'None' was not found.
Questions
  • Is the documentation example wrong or incomplete?
  • Does !remove support substitutions at all?
  • Is there a way to conditionally avoid removal?
  • Should the expression return an empty string instead of False / None ?
I cannot find any additional information about how !remove is parsed or how it interacts with substitutions and Jinja expressions.
Any help would be greatly appreciated.
I’ve done additional tests, and I found something very strange that shows an inconsistency in the substitution resolution order.
Test 1
test.yaml
substitutions:
  identifier: restart_switch
switch:
  - id: !remove ${identifier}
switch.yaml
switch:
  - platform: restart
:x: doesn’t work
Test 2
test.yaml
substitutions:
switch:
switch.yaml
switch:
  - platform: restart
:white_check_mark: works
This means when the config is validated the substitutions are not resolved so ${identifier} is different from restart_switch
It was a bug in 2025.10.x, it is resolved in 2025.11.x (#11203)
