Good evening!
during the creation of automation I found some extra folders (which were created by automations) in the media section… how can I remove the excess folders that only create confusion for me? (excess folders are empty and they are not used by automations)
You can use the Samba share add-on to browse to the media folder and delete them.
Thank you!
edit: also @ GitHub - danielperna84/hass-configurator: Configuration UI for Home Assistant
actually while it does let you create and delete folders, it doesn’t show the system root, so the media folder is not available
