Remove or ignore units?
Hello, i’m sure this is probably really simple, and i’ve probably dealt with it before, but i need a little help to know how to handle a value received via mqtt.
1678 kWh
I’m pretty sure it’s a template that is needed, i just cant quite get all the syntax.
I really just want the 1678 or whatever the value is, so that i can graph it.
Any pointers please?
value_template: "{{ value|replace(' kWh', '') }}"
This replaces ’ kWh’ with nothing.
If you have not done this already, you will also need to add:
unit_of_measurement: kWh
So that the state can be graphed as a number.
That works perfectly!
Magic, thanks!
