I have the following button on my dashboard.
Pressing it activates a specific scene. that scene is also triggered by time. (scene.living_room_scene_3)
The time the trigger is activated is defined in a time helper (input_datetime.starttime_scene3)
type: custom:config-template-card
variables:
- "'Scene 3 ('"
- states['input_datetime.starttime_scene3'].state
entities:
- scene.living_room_scene_3
card:
type: tile
tap_action:
action: toggle
entity: scene.living_room_scene_3
name: ${vars[0] + vars[1] + vars[2]}
hold_action:
action: none
icon: mdi:lamps-outline
vertical: false
hide_state: true
In the button I want to show what time the scene will be activated: Scene 3 (21:00:00)
This works, but shows the time in hh:mm:ss. I want to hide the seconds.
I have been trying to achieve this by changing the template, but this breaks the yaml.
state_attr('input_datetime.starttime_scene3', 'timestamp') | timestamp_custom('%H:%M', false)
Is this even possible to do?
There may be other ways, but you could always template the timestamp as a sensor.
Example with my devices
variables:
- "'Scene 3 ('"
- states['sensor.time_sensor'].state
entities:
card:
type: tile
tap_action:
action: toggle
hold_action:
action: none
vertical: false
hide_state: true
LiQuid_cOOled:
sensor.time_sensor
Should be added to “entities” too. Otherwise will not be “monitored”.
Thank you, forgot about that…
Also, there is no need to place static strings into variables.
Ildar’s advice is correct
variables:
name: ${"Scene 3 ("+ vars[0]+ ")"}
I’d also look into Mushroom Cards that are Tile based.
type: custom:mushroom-template-card
primary: >-
Scene 3 ({{state_attr('input_datetime.test', 'timestamp') |
timestamp_custom('%H:%M', false)}})
secondary: ""
icon: mdi:timelapse
icon_color: green
Also, in latest beta it should be possible using
name: Scene 3 (${vars[0]})
I tried to template the time helper as a sensor. but this returned ‘false’ when I try to add the new template to the button
i see it in my entities when i added the helper template? So what do you exactly mean with add to entities?
Did you go to Helpers and select Template?
Then template a Sensor
Then enter
Thanks so much, this works! Seems I accidentally selected ‘binary sensor’ instead of ‘sensor’. Lesson learned: Never program before coffee
