Remove User
I am new to Home Assistant. I have it installed on an Intel i3 computer with 4GB memory and 64GB of CFast SSD. I installed hassio directly onto the CFast disk via balenaEtcher and am running version 2023.10.3
I created users that I no longer need. I cannot find how to remove or delete them. It does not seem possible via the web UI by any means.
I have tried SSH and usng docker exec -it homeassistant bash I used vi to edit both /config/.storage/auth and auth_providers.homeassitant I removed all references between {...} in both files for the unwanted users. I then did a full system reboot.
The users are still there.
How do I remove unwanted users from my Home Assistant system please?
Pete
Settings, People, Users tab. Select the user and choose Delete User…
Yeah, just found it.
Also - if you have installed HAOS, stay away from SSH (mostly) and definitely Docker.
If you want more control, choose a different install method like Core.
Thanks guys. Having now deleted the offending users via the webUI I find that whilst the two accounts in question have now been disabled, their names and icons remain in Settings > People. Most likely my excursions into docker-lnd may well have consequences.
Your point about staying clear of SSH is well taken. It is usually my forst port of call after the webUI.
I may have to live with my mistake although I’ll try restoting from a backup too.
Thanks again.
