Removed lock from Z-Wave JS UI and now cannot remove from HA
Long story short, I was fighting an issue with locks and removed a Z-Wave lock from Z-Wave JS UI and added it again.
This eventually worked and although there is no longer an entry for the old device and the newly added same lock is now working, I cannot remove the original entry from HA.
It shows up like nothing happened. When I try to delete it from HA, I select the force remove option and then I see on the ZWave JS UI that the controller remains unavailable for a short while, and the operation times out. (Both HA and Wave JS are up to date).
Any way of deleting the entry from HA without trying to delete from ZWavaJS?
Thanks!
