Removing duplicates in a template
Background:
I have an automation that alerts when someone turns on the thermostat when any exterior windows are open.
I have multiple sensors on most of my exterior doors for redundancy. In most cases there is a YoLink sensor and a Z-Wave sensor. The YoLink sensors are more reliable and need less frequent battery changes, but they depend on the cloud. The Z-wave sensors don’t need the cloud, but I find that between dead batteries and other issues, they just aren’t as reliable as the YoLink stuff overall.
The sensors are named like using this pattern:
  • binary_sensor.master_bedroom_window_z
  • binary_sensor.master_bedroom_window_yo
The automation includes this template as part of the notification:
{% for entity in (expand('binary_sensor.all_window_sensors')
    | selectattr('state', 'eq', 'on') | list) %}
    {{ entity.entity_id
      | replace('binary_sensor.', '')
      | replace('_', ' ')
      | replace('window z', '')
      | replace('window yo', '')
      | capitalize()
{% endfor %}
The issue is that if the master bedroom window is open, the notification says master bedroom twice. How can I stop this?
Use the unique filter.
However, if you assign an area to your sensors you can use a much simpler template:
{{ state_attr('binary_sensor.all_window_sensors', 'entity_id')
| select('is_state', 'on') | map('area_name') | unique | list }}
EDIT:
  • Added the state check… :man_facepalming:
  • Fixed select filter.
Thank you for the thoughtful response. I tried your template and the output was:
['Blue Room', 'Family Room', 'Kitchen', 'Master Bedroom', 'Outside', 'Basement']
The only room that actually had an open window was the master bedroom.
If you want a list of areas containing only open windows, you need to use a filter to select only the ones whose state is on.
{{ expand('binary_sensor.all_window_sensors')
  | map(attribute='entity_id')
  | map('area_name')
  | unique | sort | list }}
Sorry, I accidentally left out the state check. I have fixed the template in the earlier post.
When I tried that I got:
TemplateRuntimeError: No filter named 'is_state'
That should have been select not map… maybe I should step away from the keyboard for a while.
That worked. Thanks.
123 Taras, your template also worked.
Thanks to you both for the help.
You’re welcome!
Don’t forget to mark Didgeridrew’s post with the Solution tag. It helps other users find answers to similar questions.
