Renault Integration Failed to setup
It should work again in 2026.5.4 as much as I understood.
Renault has changed the used Client-ID so it has to be changed in HA as well.
There is a thread on reddit and an issue in the library used by Home Assistant with some workarounds until the new version is released.
Edit:
This is the issue for Home Assistant itself
