Reolink Cameras and Remote Home Assistant
I have two (very) remote cameras at my gate. There is also HA Green there and everything woks as expected. I also have another setup at the house, miles away with Home Assistant.
I used Remote Home Assistant to link the instances, both are on Nabu Casa.
Recently I had issues and a power outage and had to change some connections as the external IP address of the remote router changed,
After getting everything linked back together, the house Home Assistant can see and work with all the exposed entities but the camera feed (using Frigate card) just shows a snapshot when starting and live view is not working. It always did before.
It works if I use Nabu Casa login of the gate system, immediately streaming the content. But it does not work if I point Frigate card on house system to the exposed entity (prefixed with gate_).
The gate and home HA cards are identical, with the exception of that.
Did Remote Home Assistant or some update break streaming remote cameras? Something to suggest I can check?
