Reolink Cameras Delay
I’ve got three Reolink IP cameras running through HA using the Reolink integration, however I get about a 30 second delay on my live feed. I’m using the sub stream, but it has a much smaller delay if I use snapshots. The problem with using snapshots is that there is no audio and one of the cameras is used as a baby monitor. What can I do to speed this up? Could it be my hardware, I’m running HA on a RPi 4 B with 4GB RAM and SSD.
For anyone reading this with the same problem, cured it by using the FLV stream which has under a second delay for me. Using the Frigate HACS card for live streams (don’t have to have Frigate installed, I don’t)
How did you configure this card? I have the same problem
Hi there,
I have the same problem. I tried to display the camera via the Frigate integration, but that failes.
@fuzzyfelt How did you manage that?
Thanks in advance!
