Hello “domoticators”.
Have any of you ever tried to use movement sensors of Reolink cameras (Mod. B400, linked to RLN8-410 NVR) with the scope to activate lights?
I am still fighting with the blueprint built for it because, still … lights switches on and off continuously after first successful activation of the blueprint.
The reason as far as I understand is that when the light switches off as per the sequence of the blueprint, it appears to the camera like something moving within its field and this restarts the loop with no end.
Here follows the ‘yaml’ created for it:
description: "Luci di cortesia_giardino"
mode: restart
triggers:
- trigger: state
entity_id:
- binary_sensor.giardino_movimento
to: "on"
conditions:
- type: is_illuminance
condition: device
device_id: c9f6fd7491a190715ddeac30a37995a7
entity_id: a07caebbef7c81a26f4bb260a957a94c
domain: sensor
below: 10
- condition: device
type: is_off
device_id: a1730b7b1edd72bd007f4eb6cacd1fed
entity_id: af95bb1aa53c98faf3112650375961f4
domain: light
enabled: true
- type: is_motion
condition: device
device_id: 338d5aefa58e23d78bcb39ecb8dd3682
entity_id: 11e1d1961386db391ab16c58d4f882d5
domain: binary_sensor
- condition: not
conditions:
- condition: state
entity_id: switch.sonoff_1001dc1c11_1
state: "on"
attribute: Automazioni in esecuzione
enabled: true
- condition: state
entity_id: switch.sonoff_1001dc1c11_2
state: "on"
enabled: true
enabled: true
actions:
- sequence:
- type: turn_on
domain: light
- wait_for_trigger:
- type: no_motion
trigger: device
for:
hours: 0
minutes: 0
seconds: 10
continue_on_timeout: false
- type: turn_off
domain: light
enabled: true
Few conditions are there to be satisfied before turning on lights and some of those comes from the meteo station on the roof, such as the environment light (less than 10 lux in my settings). Also none of the other blueprints that would switch on the same light should be already active.
I also tried to insert a delay of few seconds after lights switches off in order to let the camera “to forget” about the switch off event, but … no way.
Is there anybody able to suggest me how to solve the problem?
Thanks in advance!
