I’m using the reolink_dev add-on with one camera.
Now I want to add some cameras and the NVR from reolink.
There are 2 options to connect the cameras:
- cameras connect directly to the NVR, each using its dedicated 100 MBit LAN-port of the NVR. The cameras are behind the NVR and not accessible from home assistant directly.
- cameras in the LAN, connected to the NVR with the 1 GB LAN port. This is only recommended for 3-4 cameras, because too much traffic between the Cameras and the NVR-LAN-Port.
Does the reolink_dev Add-on supports the NVR and gets all cameras/entitie with their actions and functions?
Does anybody use the reolink NVR or another NVR with reolink Cameras?
Regards Mark
