Reolink integration has been working flawlessly for over a dozen cameras, however I’m now trying to set up an Alarm system and would like to use the E1 Zoom built in siren. It plays just fine using the Reolink APP, however i can’t seem to trigger it via homeassistant.
The Siren switch appears correctly on device page, but this is the error I get when i try to toggle it:
Failed to call service siren/turn_on. cmd 'AudioAlarmPlay': API returned error code 1, response code -9/not support
This happens for every reolink camera, even for the doorbell.
Firmware: v3.0.0.1107_22070508
Hardware: IPC_515BSD6
HA: 2023.08
HAOS 10.3
The App uses a diffrent protocol, you could check with the webserver by going to the IP of the E1 Zoom in a web browser. That uses the same protocol as HomeAssistant.
But It looks to be a firware issue.
In that case, contact Reolink support and ask them to fix it in the firmware and release a new firmware: https://support.reolink.com/requests/
If you appreciate the reolink integration and want to support its development, please consider sponsering the upstream library or purchase Reolink products through this affiliate link.
I already contacted the Reolink support about that issue.
Here the answer:
Dear Frank,
We confirmed with our engineer that since the camera is with the hardware version IPC_51X, it supports the Siren feature itself but can not be operated via the API command.
Sincerely sorry for that.
Any further help is needed, feel free to let us know.
Well that is a “helpfull” answer from support…
I guess the answer schould be:
Yes I need further help: please fix the firmware issue and upload a new firmware version. In the mean time do you perhaps have some beta firmware I can test that has this firmware bug fixed?
@Neelixx unfortunately this also means I can not help with this issue, since the problem is not in the HomeAssistant code.
The siren works in the windows client. It is visible in HA but still does not activate when the button is pressed or when requested in an automation. The siren of the wifi doorbell does work in HA, although it only turns on and not off with a toggle command.
