Reolink integration missing sensor
I have a question about Home Assistant and Reolink integration.
I currently have 2 Reolink cameras connected via the Home Hub and configured the Home Hub in HA via the Reolink integration.
The first thing I noticed was that only “1 device”, namely the Home Hub itself, is listed under the Reolink integration and not, as in various videos on the subject of the Home Hub and the cameras connected to it.
My problem is that the sensors are then called “Motion” or “Motion_2”, which I can rename manually.
What I’m also missing, however, is the sensor/config for recording or push notification for each connected camera. I only have these two configs for the Home Hub itself which not help me.
I would need these two sensors per camera so that I can switch them on or off automatically when I’m in the garden and don’t constantly need recordings/push from the garden camera.
Is this possibly due to my HA version which is still from 2024 or what can I do to ensure that the above-mentioned sensors per camera appear in HA.
Currently I always have to deactivate/activate it manually in the Reolink app.
BR
Michael
If I disconnect the Lumus Pro, which can also do RTSP/ONVIF, from the Home Hub and connect it to the Home Assistant as a standalone, I normally have the “switch.garden_record” entity and also the entity for push.
Only when I connect the Lumus Pro back to the Home Hub for recording on it do I no longer have these two entities
