Reolink integration. People detection
For a trigger event I am able to set up using the motion blueprint. But I think the person detection would be better. Person feature works great within Reolink, but I don’t see any such selection within the integration. Using just motion I’m not getting good detection without it being too sensitive to leaves. Gemini thinks it might be because cams are plugged directly into the NVR.
I don’t have an NVR, but check if you have a binary sensor binary_sensor.CAMERANAME_person that you can use.
On this page: Reolink - Home Assistant
the following attention is specified:
  • Note that almost all entities, including motion/ai detection and the camera streams, will be unavailable when privacy mode is turned ON. Check the history of the Privacy mode entity to see if this is causing the issues.
Hope you you can solve the issue with this.
Problem solved. Found them with a search under “person”. They seem to be invisible under the blueprint, which only shows basic motion. Person works much better.
Hi, welcome to the forum and good that you got it solved!
Also: please take the time to mark the post that holds the solution.
You do that by selecting the three dots under the post:
Then select the check box:
By doing so:
  • this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
  • this prevents that someone else steps in trying to help
Thanks for giving back to the community! :+1:
