Reolink OMVI 3i with Home Hub Pro
If connected via the Hub Pro, I only see the wide angle stream/entities in HA.
If connected directly, I get streams/entities for both the wide angle and PT cams.
Is anyone else seeing the same behavior?
My guess is the integration probably needs to updated to support this combo, but wanted to make sure I'm not doing something dumb.
Edit:
Using core reolink integration. Tested under HA 2026.4, 2026.7.0, 2026.7.1. OMVI/Hub firmware all updated to latest.
Assuming you are running the Core App for Reolink, the developer is very active and is likely to respond quickly to a feature request or issue on the subject. home-assistant · Discussions · GitHub
I have created a github issue.
