My guess is that the configurator works only with a single customize.yaml file. It is not sophisticated enough to work with multiple config files in a directory.
I have tried using this but not had much luck.
Im not entirely sure what it is supposed to do when used together with group.*
Will it organise groups within views?
From my understanding is that it will cause the specified groups to display from top to bottom in the order they are told.
Now that said, I’m not sure how that determines the order of the display on a screen that is wider. Like a computer monitor instead of a cell phone. I don’t know if the ordering is then top to bottom or left to right.
I don’t use it a lot. Only on the one group above to get it to display at the top. Which ends up being top left on wider screen.
it would seem not when trying to order cards on a view.
I managed to figure out a workaround…
I have to create a group or every entity on each ‘view’ and then within the ‘view’ group, the order they are referenced seems to be the order they appear. So some of my groups only contain one entity…which isn’t a problem I guess.
