Repeate phone notification
Edited:
I want to repeate a notification 3 times, with a 3 second delay. The trigger is a dorr button. I’m not good at programming, so I need help shown in my code (I got it from a video …). This code works for one time:
alias: Dörrklocka2
description: ""
triggers:
  - domain: mqtt
    device_id: 994d13e42d14f05fddf40af1b1f1cb47
    type: action
    subtype: single
    trigger: device
conditions: []
actions:
  - action: notify.mobile_app_moto_g35_5g
    metadata: {}
      message: TTS
        tts_text: det ringer på dörren
        media_stream: alarm_stream
mode: single
Hello Ralph Utbult,
Can you please fix the code formatting?
Fixed! Didn’t know that I had to use preformatted text …
OK, I can understand that.
I assume you would want some kind of time delay between the 3 notifications?
Personally I would switch from a device trigger to a state trigger, then have 3 triggers.
  triggers:
    trigger: state
    entity_id: domain.WhatEverItIs
    to: "on"
    trigger: state
    to: "on"
    for:
      minutes: 2
    trigger: state
    to: "on"
    for:
      minutes: 10
I’m sorry but I don’t understand that code at all. Where do I put my code into that?
You have to determine the entiry_id of the switch and replace the domain.WhatEverItIs placeholder I put in there, then replace the triggers: you have with this triggers: I wrote.
You can and probably should do all that in the UI editor though.
Sorry but that didn’t help at all. Where do I put all my code in your example?
Mainly this:
  • action: notify.mobile_app_moto_g35_5g
    metadata: {}
    message: TTS
Some of you may not like this :slight_smile: I solved it by using delay ‘time’ and repeating the notification code. Not pretty, but it works.
actions:
    metadata: {}
      message: TTS
  - delay: "00:00:03"
    metadata: {}
      message: TTS
  - delay: "00:00:03"
    metadata: {}
      message: TTS
mode: single
