Repenic Smart Dimmer: Zigbee Control with True Multi-Way Dimming
Hi everyone,
We’re the official Repenic team.
Building a smart staircase lighting project often means controlling the same lights from more than one location — for example, from the bottom of the stairs, the landing and the top floor.
However, many smart dimmer setups only allow one smart dimmer on the circuit, while the other positions use standard switches, retractive switches or wireless remotes. That may be enough for on/off control, but it does not always provide a proper local dimming experience at every position.
Repenic offers a different solution.
Our no-neutral Zigbee Smart Dimmer can work with up to two Repenic Multi-Way Dimmers on the same lighting circuit, allowing manual on/off and rotary dimming from up to three switch locations.
It is designed for UK homes and projects, with no neutral required and compatibility with standard UK 25 mm back boxes.
Key features include:
  • Zigbee smart dimming control
  • No neutral required
  • One Smart Dimmer + up to two Multi-Way Dimmers
  • Manual dimming from up to three locations
  • Designed for standard UK 25 mm back boxes
  • App control, automations and energy monitoring
  • Brightness memory, soft start and minimum-brightness adjustment
  • Over-temperature, over-current, short-circuit and overload protection
  • Zigbee OTA firmware updates
Our upcoming Zigbee Smart Toggle and Rocker Switches will also support multi-way control.
You can watch a real installation and product review here:
If you are interested in the product, planning a smart lighting project, or would like to discuss testing, please feel free to send us a direct message or contact us at:[email protected]
More information: Repenic
